coach
if i was to put a 20v head on a sr20 bottom end how would i go about wiring up the coil packs into the harness or is it possible to use a stock sr20 ecu or would i need to get the computer that works with the 20v coil packs. :rolleyes:
Broke Ass
You can go with standalone or just use your stock distributor instead
Old Kid driving....
But the 20V head wont fit into a non 20V Block
Yes it will. LanceSR20 put a 20V head on a 20ve block with no issues when he was going through his NA phase when he had his B13. Direct fit with no modifications whatsoever. DE block, would fit but would have to drill 20V head for external oil line to activate the cams, and the you're limited to the stock 20ve cams if you use stock DE pistons. 16ve cams would be pushing it on a VE/DE hybrid because of valve clearance. BTW Lance bought the 20V head from Andreas Miko.
