Scanning threads on the VE forum, I found a great range of "suggested" valve clearances (lash) for the VE.
Ranging from .15 mm (0.006") for BOTH intake and exhaust up to .20 mm (0.008") for intake and .28 mm for exhaust!!!! (this last one is almost DOUBLE the .15 mm !!! )
Lets try to collect all opinions (and posible info sources here)...
NOTES.
1. Valve lash is measured COLD between the cams base circle and the rocker arm at both sides of the rocker arm (i.e., on both cams) and their difference should be negligible (close to 0.01mm ???)
2. The FSM for the SR20DET (which uses solid lifters and is the closest head to the VVL that we do have an FSM for) suggests COLD valve lash between 0.14 mm and 0.17 mm (measured as in #1 above). No difference between intake lash and exhaust lash.
So, what are the proper clearances?
Should there be a differnce between Intake and Exhaust?
NOTES.
