ok guy's..
my se-r wants to or stalls out when:I start it,came to a quick stop,and even just rev..I've changed spark plugs,filters,O2 sensor...even installed a rich/lean gauge to see if it was running to rich/lean...could it be because it is a primera motor..HELP PLS?
· SNAIL SQUAD
You might want to check your throttle cable adjustments. I had the same problem in my classic. When I would come to a quick stop my car would stall with no hesitation. It would just shut off. My adjustment cables were loose. I hope that works out!
RED 92 CLASSIC
ROD KNOCK ,NOS,H/S HEADER,MSD,INTAKE,EXHAUST, ACT CLUTCH AND PRESSURE PLATE (IN THE PROCESS OF A PRIMERA MOTOR SWAP AND INSTALLING PR CAI AND SHORT SHIFTER)
Mine's doing it too. Hopefully this weekend it'll get sorted out.
nizzan4u2nv said:
Adjust throttle cables, timing, and check TPS.
checked the TPS
my timing, now thats where it gets weird, when you check the timing using a timing light it looks as if the timing is 20+, and by 20+ way over the 20 mark
but there is no way that is possible with out massive deto, right???
also my ECU still reads a bad temp sensor(just replaced it), so that could have something to do with it too
