NO ONE can help me out with this?
Gino
Gino
I will try this soon... thanksBruHaHa said:Have you tried cleaning your throttle body. Mine had the "stalling when you come to a complete stop after driving above 30mph" problem. Did just a minor clean-up of the throttle body and the problem was solved. New plugs and distributor cap/rotor didn't do much prior to the throttle body cleaning. Hope this helps.
I would start by adding an extra ground to your maf, then check base idle (I always recommend this!), and also check your fuel pump pressure. If you are not sure about any of this- go to www.se-r.net it explains how to do just about everything.gTeknikal said:So I have these 3 problems going for me. First, in the mornings, the idle is very irratic. It'll start going up and down,up and down. Then when I throw the car in neutral, it'll shut off on me when I get to a complete stop. AND while I'm normally driving the car (especially on the freeway), it'll stall REALLY bad. Start choking pretty bad. Everytime the car shuts off, I have to give it gas to start it up again. I already changed the fuel filter, but didn't seem to do to much of a difference. From reading an earlier post, seems like my AAC valve, but I don't have too much background about the AAC valve. Any suggestions??
Thanks,
Gino
