ok i have a 1991 SE-r undergoing a bb swap. do i use the starter ring from the bluebird or the starter ring from the usdm motor?? my assumption would be to use bb one cause it lines up perfect with usdm tranny... and block... please help... thanks in advance...:biggthump
Are you talking about the metal gasket that goes between the transmission and the engine? If so, either will work.
yes i was and thank you again for the response! mods feel free to close
