OK I just put my SR20 B13 back to stock. When I start it up for the first time it starts right up. Now if I ride for a bit and park it for 5mins or so when I got back to start it, I have to crank it for a long time before it will start. I have to crank it for a good 5sec or longer before it will start. any ideas?
the fo do
Your motor is having boost withdraws and is craving more psi into the intake manifold:rolleyes:
the fo do
Have you actually done any troubleshooting? maybe some of your injectors are getting air or maybe your fuel pump is dying? It could be alot of things..maybe your fuel pressure is too high or your injectors are too big...say waht you have done and tehn maybe someone can help you...
