Hello everyone-
I was sending this email to inform everyone that my tranny has lasted
12,000 miles since December 2000 until now without any complications. I
recently turned 115,000 miles on the odometer. That means the tranny has
lasted through at least 8 dyno pulls @ 19-20 psi; which have netted me a
best of 349.6 hp & 301.9 ft/lb to the wheels, and over 25+ passes at
Firebird International Raceway here in Phoenix, AZ. The car has ran a best
of 12.0 @ 118.77 mph even with the temprature being in the 90 degree range!
Note, I drive this car to and from work everyday!
http://members8.clubphoto.com/louis419830/439477/guest.phtml
Louis Anaya 1992 Sentra SE-R
349.6 hp & 301.9 ft/lb @ 19 psi, 12.0 @ 118.77, Bluebird SR20DET, T3/T04E, Deltagate Wastegate, FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Yokohama 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24.5x8x13 Slicks(Drag)
[This message has been edited by APEXSER (edited 07-27-2001).]
