My windows are a royal pain in the butt to roll up. Does anyone know what parts need to be replaced to fix this?
Find some silicon spray, and use it on the front and rear track of the window, roll the window up and down a few times. You may try spraying the area a few times during this time, and the windows will be easier to roll up and down.
Eric Waterman
1996 200SX SE-R
1997 200SX SE-R
1991 Sentra SE-R
remove your door panel there's piece of your weather stripping rubbing up against you widow when you roll up.you'll see it when you crank it up slowly fromup top. trust me! just cut a little piece.
91 SE-R,10:1 comp.pistons,balanced &blueprint rebuild.comp.4angle valve job,extrude honed heads/intake manifold,No emissions.crap,RC TB/MAF,nismo cams,UR pulleys,stillen4-1 ceram.header,nismo/centerforce dual fric.clutch,PR CAI with POPchgr,2 1/2 test pipe,mandrel 2 1/4 superturbo ex., ZEX flywheel & JW 50 shot nos with 60 shot jet. and much more goodies!
and grease up the tracking while your there.
