Just wanted to know if you made a gill for a 93 to 94?? Also what is holding you stillen kit up.. I put double sided tape but its not holding it up long. Help please.
Richie Soliven Representing Split Second Racing in Va beach,VA---- http://www.geocities.com/splitsecondracing/
SR20DET Power, HKS EVC EZ( boosting at 10 psi), HKS TURBO TIMER, JWT ECU , Greddy catback exhaust, 3 in ATR Race Cat(That is hollowed out), 3 in downpipe,300zxTT fuel pump HKS plugs,Magnecor wires, 5Zigen 5zm, relocated battary to the trunk, AGX'S struts and Ground Controls, Stillen kit
NO rivets it looks "CHEESY"... please just clean the surface with reduser....
91 SE-R Stillen header,HKS/Greddy catback,Nology coil/wires,ACT clutch,Clutch Masters flywheel,CAI,Energy motor mounts,Stillen S/T shifter and still not fast enough...
take it off clean with prepsol and alcohol then use 3M double sided tape pros use this often on kits. and you're done, rivets can be used and covered with some putty and sanded,painted etc and you won't even see them but a body shop would have to do it.
