www.motorists.org
Which is it? I've heard "mine came with a 7psi wastegate spring" and "mine came with a 10psi spring." Is this choosable? Do they give you both springs with your purchase?
Ben98SentraSE
98 Sentra SE TURBO and crashed 93 NX2000
If you get the FMAX kit with the standard Deltagate external wastegate, you can choose either a 5-7 psi spring, a 7-9 psi spring or a 9-13 psi spring.
Louis
www.motorists.org
I will be getting the HKS wastegate. How about on that one?
What kind of boost levels do you want to run Ben? HKS has different spring rates also, but it depends on what you want to run on the street! Have you looked into the Tial wastegates FMAX offers? They are very nice are cheaper than the HKS unit!
http://members8.clubphoto.com/louis419830/439477/guest.phtml
Louis Anaya 1992 Sentra SE-R
349.6 hp & 301.9 ft/lb @ 19 psi, 12.0 @ 118.77, Bluebird SR20DET, T3/T04E, Deltagate Wastegate, FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Yokohama 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24.5x8x13 Slicks(Drag)
