I have never used an impact in all of the bazillion times I've had mine off. Last time was the same as everytime. started by hand, made up with an extension and socket, then used the ratchet when it got tight. As soon as I started to torque it, it let go. I just chalked it up to wear and tear from old age.
i drilled through the cross member holes throught the frame and now i have 2 grade 8 bolts washers and a couple nuts holding it up in the front. i was planning on doing the same with the back but ill have to drop the subframe for that.
i stripped mine too, an impact never touched those bolts. I agree that they are very easy to strip. I just retapped mine to a larger size and its been all good since
A larger size? With what thread? I am intimidated by the helicoil. I do not want to drill out the hole and make it too big.
Also, Helicoil is not cheap and you will only use liek 2 tops? What do you do, sell the rest back to someone as used?
ive only got 1 bolt holding mine, its always pretty easy to put on when your motor mounts are older but when you do the inserts you can really tell the difference.
thats the thing about those finer pitch threads man, sometimes it feels like theyre going on straight, but by the time you realize they didnt, its too late... hehehe another factor i believe to cause that is that several people usually scrape that crossmember or have worn out mounts so alot of different pressures ar applied to it, so it may not line up exactly right... I too have never had a problem with mine and just put it on the other day, but those are just some things i can imagine that would cause that... usually a quick fix unless you really monkey gunk up the threads both on the member and the bolts....
