1 - 12 of 12 Posts
FWD PWNAGE IS HERE!
The stud pictured below was in my t28 but somehow the threads got smashed on one side so I need a replacement. Does anybody know where to get one or have any suggestions?
TIA
Nissan. The stud from a Z32TT should be the one. I can get ya the part # if ya need.
That doesn't look that bad, why not find out the size and run a tap thru the hole and a die on the stud to clean the threads.
If its smaller than the Exh studs, might be the same as a stud on the Intake Man.
70/30 Racing
its like $1.25 for a new one at nissan. just go down there and buy one from a 1990-1996 twin turbo Z.
FWD PWNAGE IS HERE!
Discussion Starter · #12 ·
Just a note for everyone... the stud from the z32 is a bit shorter than the stock one but it still worked. Although I would probably look for a longer one next time.
1 - 12 of 12 Posts
