Hi.I have a problem with my sunroof.Sometimes it works sometimes not.The fuses are ok.What i must see?Does anyone now were can i find the cables from the roof?
My car is the Sunny GTi ,made '92
Thanks
Discussion Starter · #2 ·
There are 2 things that I can think of.
1. There is a short somewhere in your electrical system
2. Or your motor is either dying or it needs to be cleaned.
Brent
mine used to sometimes work but I had to fiddle with the switch so I took the switch out and cleaned the brass contacts inside with a pencil eraser and wallah no more problems. just be careful not to lose the little plastic buttons that go on top of the contacts! also pry the switch plastic from the driver side. 10 minutes worth trying
