Okay, here is the deal. My shocks are shot and I want a new setup.
I will go with either the Motivational Engineering setup with GC coil overs (dropped about 2 inches) or AGXs and GC coil overs(dropped about 1 inch).
Can someone provide a comprehensive list of all the misc. items (and prices if possible)that I will need to install along with each of the above options (i.e. bushings, camber plates, new bolts, sway bars, etc.)
The reason I am asking is that I can afford to spend 1300-1400 on the motivational setup but that is about as much as I want to spend so if it requires a lot of extras I will most likely end up going the other route.
-----------Josh
'93 NX2000
not quite stock
-----------Josh
'93 NX2000
not quite stock
