back again
has anyone tried to swap out a whole harness from obd2(b15) to obd1?
ive had problems with my car since i purchased it. no one can figure out whats wrong with it so to solve the problem ill clear the canvas by swapping out the motor, harness, and ecu. id like to swap it out with a det which will most likely be obd1. does anyone one know what wont plug up? cluster? alternator? a/c? speedo? even simple things like the fans? im sure i could rig some things up but things like the cluster might take me longer to figure out.
back again
Why would I need a step down harness if I'm swapping the whole harness? I don't think you understood. I want to swap out the harness for a obd1. My question is would the plugs match for things such as tranny? Cluster? Alternator? A/c?
