GoinSleeper said:
That 'someone' is wrong. If that were true there wouldn't be any 'synthetic blend' oils (a combination of synthetic and dyno)
GoinSleeper said:then someone told me that you cant go back to regular oil after you start using synthetic. is that true or should my idea work with the cheap stuff for a week?
based on.............................amsoil marketing literature?mobile one sucks.....amsoil is the **** ......just my .02
If this problem developed from switching to synthetic and was never the case before, then the answer is because synthetic has detergent like characteristics which cleans out all the gum and carbon build-up deposited by the years of using cheap oil. If you really want to clean out your engine, you can use the Mobil 1 drive clean oil, or else you can just continue using synthetic.GoinSleeper said:i was having a problem with my oil being really thick and black. im using mobile one synthetic and i just put it in not too long ago. ne ways i was thinkin about flushing it by running some random cheap oil for a week and then goin back to the synthetic. then someone told me that you cant go back to regular oil after you start using synthetic. is that true or should my idea work with the cheap stuff for a week?
The amount of hp gain depends on going from what oil to what. Going from 10w40 to 5w30 Mobil 1 synthetic can often gain you anywhere from 3-6hp but it also depends on the condition of the oil you're changing out. Going from 10w30 to 0w30 won't gain you much because their thickness is the same at operating temperatures although 0w30 provides better protection for cold starts. If you want power, go for the new 0w20 Mobil 1 syn. I know people will say the manual suggest using 5w30, but that's only because 5w30 was the most economical low viscosity formula offered at the time of publication. Later 0w30 became common and now very recently another breakthrough from Mobil 1. Your car might eat a little more oil which shouldn't be a problem That will be the next oil my car's going to see.sr20andafalcon said:i have some interesting facts i know a local drag racer who runs in ihra ricky smith is his name.they dynoed with different oils and picked up 25 horsepower with one oil and lost a few with others i mean they are running 2500hp motors on our scale it would probaly be like a half hp are something but i thought it was pretty cool anyway.i heard u can pick up small gains when using synthetic is this true?
serchef said:mobile one sucks.....amsoil is the **** ......just my .02
You say "utter bullshit". Why you write "udder" (bovine mammary glands) is utterly beyond me...ohh will i thought i was the only person who said "udder" bullshit
