Will a T25 outlet (intercooler pipe) fit onto a T28...I just need to know if my intercooler piping will need to be redone if I upgrade to a T28 with a git-r manifold, etc....
Recovering Rice Boy
Assuming your turbo will sit in the same position as mine. (Clocked slightly to clear oil drain) The outlet pipe will have to be modified. The pipe has to be cut in half and the upper half rotated to face out to prevent it from bumping the exhaust manifold. The outlet pipe is aluminum so you have to take it somewhere that tig welds. Most muffler shops only have mig welders. IIRC it cost me 40 bucks. You could always go with a 300zx TT outlet pipe that is short and allows you to route your IC piping anyway you want. Again IIRC they're pretty cheap too.
