For sale: T3/T04e turbo and Rev-hard manifold
Used Garrett T3/TO4e turbo:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
standard with 270 degree thrust bearing
oil lubricated centersection.
Very little to no shaft play except whats needed for it to spin. Bought it used, never mounted it. The guy i bought it off of said it had roughly 4000mi. on it. Comes with the oil line and coupling.
For the manifold:
Rev-Hard manifold
Its the revised manifold,
1/8th EGT gauge hole pre-drilled in the 4th runner.
Pre-cut to insure it won't crack
Flanged for T3 or T4 and a Tial or Deltagate 35/38mm Wastegate
Same as turbo, havent mounted it to the car or anything yet, comes with exhaust manifold gaskets that are slightly used, still in good condition.
$300 each plus shipping O.B.O.
