Guest
·Guest
Some a$$hole (I call them that because it was a hit and run) hit my '92 NX2000 and smashed the driver's side tailight to bits. I need to replace it now. There is slight body damage under the light assembly that I think I can pull out when the light is removed. Has anyone else on here replaced their tail light before? If so, what is involved in it? How do you seal the new one to keep water out? How do you get the old one out?
Thanks...
Thanks...
