1 - 20 of 34 Posts
employment whiplash, NC
Alrighty, so I get to fix my 5th gear now. I almost pulled the trigger on one last November when I (with help from friends) replaced my clutch. But now I have a nice tax return coming...
So. Who has one? Tell me about it.
Is it a viscous type like the OE, or mechanical like a Quaiffe?
Will it wear out like the OE?
Straight forward install?
Where's the best place to get one?
Thanks!
Coropate greed hater
The Nismo LSD is not viscous, that I do know. If I remember it right, its a 1.5-way mechanical diff, although a little different than Quaife. Jacen99se has one in his car. PM him and ask him what his thoughts are on the Nismo LSD.
I'd say any part will wear out over time, although I'm sure the Nismo unit will have a longer life than the stocl VLSD.
I guess the best place to get one would be through a dealership. That's the only way you can get Nismo parts in the USA, AFAIK.
fabricator
It is not viscous like OE, or gear-type like a quaife. It is a clutch type diff. They work really well. It will last much longer than a viscous diff. For the most part, I don't think diffs like this even wear out. It uses stacks of metal discs to create friction. KAAZ diffs are like this, as well as (iirc) tomei and some OE brands. It has much more positive traction and grab out of corners than a viscous diff. It will not do the wierd Quaife thing where it doesn't work when one wheel is unloaded, and also is a little more progressive than the quaife. Not to mention the fact that you can't even buy a quaife anymore :) It is a solid buy. You can get it from any Nissan dealer. Search, i think someone has posted the part numbers. You will want to buy a new speedo drive ring (you'll trash the old one trying to remove it) and I'd personally just buy new bearings to press onto it. I've taken apart and rebuilt several Mazda diffs that use the same type of mechanism and it is very simple and robust.
andris
andris
The clutches do wear after a while but it can be rebuilt. Wear only affects the static breakaway torque because the diff will still lock when there is a speed differential between the wheels. The Nismo diff has a cam on the pinion shafts that applies load to the clutch stacks in proportion to the speed differential of the wheels.
Mike
I hear it is not as progressive as the Quaife. Of course the Quaife is not an option.
Matt, Just get it. You know you want it. You know you need it. It will be very good for you. It is designed just for you. Great Diff, Great Price. Call Brian and Greg. See who will give you the best price.
Bitter Old Man
38420RS360 is for the NON LSD tranny
38420RS365 is for the LSD tranny (like Matt needs).
Matt, please confirm the part before you order. They should have no problem looking these up and making sure you get the right one. I have always been of the opinion that you don’t tell a shop what part # to order but what part you need and then they look it up and get you the right part. That way it's them that screws up not you.
Proud father of two
Thanks Steve for FINALLY clearing that up for us. :)
On a side note, I just called my dealer and they only have the P/N RS360 for the "non lsd" tranny. I'm going to try my other dealer to find out.
Bitter Old Man
Whoa...easy there Bruce. I don't want you keeling over with a heart attack or anything!
Well, Harris quit as Search Nazi, so I'm picking up some of the slack.
1 - 20 of 34 Posts
