ive been researching spots to tap for a turbo oil return. and it seems like tapping the pan would be the easiest and noob proof method of doing so, i also read that one should tap the lower pan...
i have a couple questions, where should the lower oil pan be tapped, or should it even be tapped would it be better off tapping the upper? .
and if i were to tap the oil pan, wouldnt the tap be below the oil level and would that give me a problem and force oil up the return or some how limit oil drain from the turbo?
where on the pan should a tap be placed, and what size tap
