is there any need for the timing chain guard? if theres no need for it, is it hard to take off??has anyone heard of you not needing one?
the timing chain guard is under the valve cover, nothing should get caught in there, unless you run your car without a valve cover [in which case you would have other problems]sleeping 91ser said:reason I ask is, cause couldnt **** get caught up in the chain potentially, like maybe some extra wires around the engine bay
huh? what he said, it's internal.sleeping 91ser said:reason I ask is, cause couldnt **** get caught up in the chain potentially, like maybe some extra wires around the engine bay, I would think it would be a good idea keeping it there so I it wouldnt be on my mind. I guess if you have adjustable cam gears it would make some sense
