1 - 13 of 13 Posts
my car has 60k miles already and i wanted to know when should the timing chain should be replaced or adjusted???
what causes a timing chain to be damaged or stretched????
so wats the advantage of the timing chain over the timing belt??? is it that it never needs replacement or maintenance????
ok this poses another question (not meaning to highjack the thread :D), when you get the chain rattle off the top chain guard, what do you do then? In many cases, changing out the chain tensioner does NOT solve the problem. It seems that the only option is to do a full timing chain kit change. Is it ok to remove that top chain guard? the noise is horrible, but i thought that removing that guard could cause the chain to possibly skip a tooth, then again, some of the SR20's don't have that top chain guard.. ???
· Rattle Box
My engine doesnt have the top guard...all though i have questioned why my engine/valvetrain is so loud, and someone told me to check out the timing chain. I wouldnt worry about not having the guard.
· Coropate greed hater
Storm88000 said:
...unless it breaks.
Which is a RARITY, I might add.
The only way you could really snap a chain is by neglecting the motor, over-revving it all of the time, or simply due to the passage of a hell of a lot of time. I've seen motors die more because of something other than the timing chain snapping. That's the advantage of timing chains; they are supposed to last the life of the motor. Timing belts, however, need to be replaced every 60,000 miles or so.
Timing chains--no maintainance, last forever, heavier.
Belts--lighter, must replace, but you get that slight retard of timing at high rpm, which is good for power.
It's funny--I had that chain rattle noise at the top for a while...then it went away. I've been using MOBIL-1 for the last year and a half, maybe that's why?
· Tired Greasemonkey
we just got done rebuilding a ka24e engine, the tensioner broke and the customer kept driving it until the chain rubbed a grove in it about 1/2 inch deep.
crazy.
timing chain is not serviceable, if it breaks, time for a jdm
I´ve been reading many of the topics regarding the timing chain.
I think this is bad advice. Timing chains stretch. That retards the cam timing making you lose low end torque and probably efficiency. Is there something special about sr20de timing chains that they don´t stretch? Timing chains last much longer than belts but I think it´s foolish to never change the timing chain set. And the higher rpm an engine runs the quicker the chain stretches.
I´ve replaced the timing kit in Toyota 22re, Nissan KA24E, and an old Ford V8. The stretched chains retarded the cam timing terribly in the 22re and 351C. The loss of low end power was noticeable with the KA24E too. I´d say you´re lucky if you get 150,000 miles from your timing chain on any of these engines. I had the first 22re chain changed at 150,000 miles shortly after it destroyed the guides and starting eating into the timing chain cover. I recently replaced the second timing kit on the 22re at 300,000 miles. I think the second chain performed better since it wasn´t often driven at 75 mph like the first timing chain kit.
If you´ve got more than 150,000 miles on your timing chain kit and have the time and ability to change it, I would do it.
I need to replace my timing chain tensioner soon and I´m tempted to replace the entire timing chain kit on my 180,000 mile sr20de.
1 - 13 of 13 Posts
