i installed a new timing chain tensioner, but the timing chain still rattles. i have also taken off the upper guide. what else could be causing this? is it the lower tensioner? if so, should i just start saving for a new engine, and about how long do you think i have on this one. at first i could hear the chain running up against the front of the chain side of the engine, but now it is making a cricket noise at idle, intermittently, like, not all the time. what do yall suggest i do. if the lower tensioner needs to be replaced, from what i've heard, it's best to just buy a new engine. is this true? someone set me in the right direction. thanks - jeff
