1 - 8 of 8 Posts
Egg Lover
I have been checking my timing on my 93 NX2K. I have disconnected the TPS and revved the engine to 3000 RPM 3 times as the directions say. When the fan is running it reads between 12-14 degrees. When the fan stops it reads 15-17 degrees. Is it normal for the reading to change when the fan comes on? Should I try to set it for what it reads when the fan is on or off? Thanks.
<font face="Verdana, Arial" size="2">Originally posted by keithert:
I have been checking my timing on my 93 NX2K. I have disconnected the TPS and revved the engine to 3000 RPM 3 times as the directions say. When the fan is running it reads between 12-14 degrees. When the fan stops it reads 15-17 degrees. Is it normal for the reading to change when the fan comes on? Should I try to set it for what it reads when the fan is on or off? Thanks.</font>
Yes, it is normal for the timing readings to be different when the fan is on or off. You want to set the timing when the fan is off.
Interesting... I've only seen the timing advance, not retard, when the fan turns on. Are you reading the timing marks correctly? Just curious... Here's how to read it
-5 0 5 10 1315 20
<----firewall front of car---->
pwnd
Yup thats typical. Eric and I had that problem with mine when setting the timing. Stupid b13's are so not fun to time
93 classic
Off-Topic lurker..
just disconnect the electrical connector for each fan before setting your timing?
Aztec Red 1993 NX2000
<font face="Verdana, Arial" size="2">Originally posted by RollcageSR20:
-5 0 5 10 1315 20
I couldnt figure mine out it only had two dashes and not big paint mark, looked like this:
What the hell?
Stock (except for sticky Dunlops 8000's) '91 NX2K
Off-Topic lurker..
yes, that's right...that's why you just unplug the connectors BEFORE you set your timing..
1 - 8 of 8 Posts
