Well I just tried resetting my timing on my 96, and something was wrong. Let me explain this as best as I can. I went through the proper procedure on preparing the car on setting the timing. As noted on se-r.net, and my Chiltons manual. Well first off my car idles fine when the tps is connected but as soon as I disconnect it the idle goes up to approx 1400 rpms. NOw I remember when I set my timing waaay back the idle dropped when this was done. Well I thought nothing of it and continued the process. Well here's the part that lost me. At that rpm my timing was reading I'm guessing about 25-30 degrees. Now this can't be right so I started backing the timing down well then the rpms drop and I'm all of a sudden at 5-10 degrees. Now I threw an engine code a while back for my O2 sensor and have since reset the ECU. I think the problem was I didn't reground my CAT when I was doing my header install. Could this be the problem? I'm just really worried about my erratic timing because I want to be able to safely set it for running NOS. Other then this little quirk my car runs great, at least to me it does. Can someone shed some advice please. thanks
96 se-r with a few goodies
