1 - 16 of 16 Posts
hey dudes - last week i posted a how to install chain tennsioner? anyway before i did this i thought i would pull the rocker cover off and have look at the chain guide - that was the problem - i removed it and now the problem is solved
my question - is it ok to remove this thing? (my chain has no play i could not move it at all)
Has anyone else done it
· Coropate greed hater
You took your rocker off? I hope you meant valve cover. And yes, its ok to remove the guide. Nissan stopped installing them in the SRs here from '98 and up, IIRC.
· 4th sr20 and counting..
my chain makes a lot of noise, i think its just dragin on the guide,, if i replace my tensioner, and remove the guides, ill be fine?
this is great news,, i was going to buy new guides from nissan too ($$73.XX) each. i already have my tensior, which cost like 28bucks..
Harris said:
The guide I'm talking about removing is the top one, by the cams. Just FYI.
okay, this changes a lot than.. so u cannot remove the other ones than. i already replaced the one up near my cams, that part was only a few dollars....
I don't know if you can remove the other ones and run the car safely, but I do know that the one by the cams does cause the chain to rattle.
thanks for getting me straight with this guys... i guess ill be pulling my VC tomorrow and pulling the top guide.. i hope this does it for me.
Did the 94-96 G20s have them? If they did, maybe I see the picture, and it ain't a good one either!
lol...this noise cannot be normal...this topic is going too many different ways now too... i have a high port if it matters.
1 - 16 of 16 Posts
