What tire pressures are you guys with stock 15" SE-R wheels running?
Right now I am have 205/50 Pirelli P700z's with 37-38psi in the front and 34-35psi in the rear. I got those numbers from Kojima on SE-R.net. Anyone else?
Stormy
'98 SE(R) w/ HS CAI, HS G3 Header, Custom 2.25" Exhaust, JWT S4 Cams, UR Pulleys, KYB AGX's, Eibach Spings, Courtesy F&R STB's, ES Mounts, ES control arm bushings & shifter bushing (NI), Brembo X-Drilled Rotors w/ Axxis MM Pads, 205/50 Pirelli's, Nis-Knacks goodies
www.WhiteLineRacing.com
Stormy
