Did anyone ever end up testing SR20 cams by Toda? I've got S4's right now, but wondering about alternatives, and can't find any solid info on Toda's..
92 NX2000
Intake/Headers/Exhaust/Cams/Flywheel/Street Tires
14.545 @ 95.54 mph
Whisky Tango Foxtrot
<font face="Verdana, Arial" size="2">Originally posted by Son Of Skyline:
I wasn't able to get any good info from Toda Racing (AKH trading). I do know that you need to convert to mechanical valves or something that is $135.00 above the $560.00 for the cams. I am still contemplating do it and getting the 272 or 264 cams with 10.5 lift.
Here are Toda Cam Specs:
Toda Cams SR20-IN002 SR20-EX002 248 11.0mm Lift
Toda Cams SR20-IN001 SR20-EX001 256 10.5mm Lift
Toda Cams SR20-IN011 SR20-EX011 264 10.5mm Lift
Toda Cams SR20-IN021 SR20-EX021 272 10.5mm Lift
http://members8.clubphoto.com/louis419830/439477/guest.phtml
Louis Anaya 1992 Sentra SE-R
349.6 hp & 301.9 ft/lb @ 19 psi, 12.0 @ 118.77, Bluebird SR20DET, T3/T04E, Deltagate Wastegate, FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, Autometer Shift Light, Fiber Images Carbon Fiber Hood, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Yokohama 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24.5x8x13 Slicks(Drag)
<font face="Verdana, Arial" size="2">Originally posted by APEXSER:
That's all the street cams. Can't forget the Race cams, but those are race only application.
<font face="Verdana, Arial" size="2">Originally posted by Soupaflie:
[/B]
The street cams are for hydraulic lifters not solid lifters. The only thing you need to change out are the valve springs and retainers if you go with the Race cams!
Oh, thank you so much. I was told I had to convert to mechanical to use any Toda cams. Looking at my Toda Racing catalog it differs from what is on AKH's website now. I could never get answered from them if the cams worked in the front wheel drive version vs the rwd. You know, the distributor issue. Any insite on this issue?
