1 - 11 of 11 Posts
I ran my car at Firebird International tonight. I hit a best of 12.4 @
114.6 mph. The car felt really strong all night. It was cutting out above
7000rpm though. I guess its time to install the MSD ignition. I also have
dyno'd car before I went to the track for the 2nd week in a row. Last week
with my car I dyno'd 311hp / 292 ft-lbs to the wheels. This week I added
some JWT S3 cams and my dyno results were 363hp / 325 ft-lbs. I still need
to do some fine tuning on the dyno but I am pleased with the results and the
times that I ran at the track tonight.
Again thanks to Ben Benavides, Louis Anaya, and everyone else that helped me
out @ the track tonight.
Ryan Nielsen
98 Sentra SE Turbo
12.99 @ 107
311hp / 292ft-lbs
Sponsored By:
Apex Motorsports
(480) 967-6515
FTF Motorsports / Racing
www.ftfmotorsports.com
Forgot to update the sig line.
Test.
Ryan Nielsen
98 Sentra SE Turbo
12.4 @ 114
363hp / 325ft-lbs
Sponsored By:
Apex Motorsports
(480) 967-6515
Pew Pew Pew
So you mean to tell me that you gained 52hp to the wheels with just adding those cams? How is that possible?
Storm88000 Any comments?
Sorry I couldn't resist. So I guess Andreas was right.. again...
(not in any way shape or form directed to Ryan..)
[This message has been edited by Matt4Nissan (edited 09-09-2001).]
Jay Hassinger put down some impressive numbers with his S3 cams. 409 horespower I believe, he was running water injection and C16 race gas. He also had a divorced wastegate and a 3-inch downpipe, oh, I also forgot, pullies. It think if you tried some C16, maybe played with(advance) your timing, you could be knocking on the 400 WHP door!
Pew Pew Pew
The reason why I made that post was, a certain member was questioning another member for him claiming that on heavily tuned/turbo'd cars a 50hp increase is possible.
I am proof that its possible I guess. I will post the overlay of the 2 charts together as soon as I can get ahold of them at the dyno shop.
Ryan Nielsen
98 Sentra SE Turbo
12.4 @ 114
363hp / 325ft-lbs
Sponsored By:
Apex Motorsports
(480) 967-6515
I run a custom turbo kit that uses an FMAX manifold, Turbonetics T3/T04E turbo, FTF Motorsports fuel system, JWT ECU, and S3 Cams.
As far as the cams. They are just that. No cam gears no dyno tuning. Just off the shelf S3 cams.
At 20psi the car made 311hp. After the cams the car made 363hp at 20psi. No bullshitting here. I will scan last weeks dyno chart when I get a chance and have the dyno place lay over the two dyno charts so we can compare the power curves. I was very impressed to say the least at the gain of 52hp to the wheels with these cams. Ben Benavides put them in for me and thats the only thing he did. No special **** here. Just a basic cam install.
I will get together a full list of whats on my car and post it soon.
Ryan Nielsen
98 Sentra SE Turbo
12.4 @ 114
363hp / 325ft-lbs
Sponsored By:
Apex Motorsports
(480) 967-6515
Nice runs Ryan! 400hp Club here we come!
http://www.sentra.net/solm/august01/louis.shtml
Louis Anaya 1992 Sentra SE-R
349.6 hp & 301.9 ft/lb @ 19 psi, 12.0 @ 118.77, Bluebird SR20DET, T3/T04E, Deltagate Wastegate, FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, Autometer Shift Light, Fiber Images Carbon Fiber Hood, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Yokohama 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24.5x8x13 Slicks(Drag)
Discussion Starter · #11 ·
Yup, Both are cars will be above that mark soon! I am going back to dyno soon... I will let you know when Louis.
Ryan Nielsen
98 Sentra SE Turbo
12.4 @ 114
363hp / 325ft-lbs
Sponsored By:
Apex Motorsports
(480) 967-6515
1 - 11 of 11 Posts
