Yes that tranny will work fine. The only thing that comes into play with ABS is there is a ring on the hub side of the axle so the speed sensor can pick up the speed each wheel is going at.
Basically swapping LSD equipped tranny to LSD equipped tranny the old axles from your se-r will work. You could not use the g20t axles though as the hub spline is different than the se-r.
