tranny leak and starter problem (please help)
Was looking under the car today and noticed this leak. What is worst case scenerio here? Best?
The car has 153k on the chasis.
Was looking because car isn't starting (not even turning over, checked battery). Tried tapping starter-- nothing and I just got it replaced a year ago. What's the better one to get the mitsu or hitachi?
Any help suggestions would be appreciated for either issue
--eduardo
SE-R Searcher
Re: tranny leak and starter problem (please help)
--eduardo
car doesn't start= starter, battery, aternator, clutch safety switch.
if the tranny is leaking it may be the switches or the axle seals. probably not related to the starting problem
While my 92ser was on ramps during a header install, i noticed my tranny would drip fluid (about a drop every hour or so). But now that it's down on flat ground, no leak. That probably doesn't help you any.. but i thought i'd share.
-patchy
