Can someone tell me which bolts in the tranny are the fill and drain plugs? Is there an FAQ on changing the tranny fluid, I can't seem to find it on ser.net.
And what's that thing that has a plate covering it and a philips screw holding the plate onto the bottom of the trans casing? Is that covering the drain plug?
SeRKid
Living up Boost
The drain plug is easily visible under the tranny as it is big. To get it out you can use a 1/2" rachet (just the rachet end with NO sockets on it). The fill plug is up higher on the tranny towards the front of the car. You need to use a 1/4" rachet on it. Click here for detailed instructions.
-saaby
Thanx Saaby! I had a feeling those two square holed plugs were it, but was unsure what to do. Makes me feel like a fool, but at least I know what to do now. Take it easy. Later.
jo mom
i honestly feel you need an impact to get the bolts to turn if the fluid was not changed recently
i started tugging on mine and gave up in fear of rounding them off
Living up Boost
I changed my fluid after only about 25,000 on the car. The drain bolt was very hard to open. I used an extension pipe around the ratchet and it popped free. You just have to jack the car up as high as you can.
-saaby
I changed mine after 140,000 miles. Didnt have to use an impact, thank goodness!! The one lesson I learned was this:
If you unscrew the fill plug first then the drain plug, that fluid will come flyin out like Niagra falls!!!
It totally missed the collector pan I had and got all over my driveway!! :mad: :mad: :p Talk about a biohazard scare!!!
Im glad no neighbors were snoopin around!!!!
