If you are kyle and work at a nissan dealer then you should be able to diagnose it better than us. also, you need to add more details on when it is happening. my first guess is the throwout bearing, happens when clutch is out, but has nothing to do with engine speed. if engine speed makes it happen then check your oil. maybe it is low. maybe a rod bearing, but dought it. does the noise ever go away? bla bla bla
