WOW!!! another auto classic. Im amazed you are only the 3rd that I have talked to counting myself. Welcome
As for fluid, I cant remember for the life of me and the hanes is out in the car. I will look it up and post it soon. Or just go grab you a hanes, think its in the owners manual too.
Brake fluid, well most people around here recomend the expensive racing fluid. I felt that I didnt need 6 dollars a pint Motul 600. So I went to walmart and grabed a quart of the valvoline syntec fluid, think its in a new bottle now, but its like a bronze type color bottle. Its good stuff, has as high, or higher cant remember, boiling point than Motul. Its dirt cheap, a quart was like 3 bucks or 5 bucks. I used a whole quart flushing out the brake lines on my car. Really helped the peddle feel too, even tho im dieing for the braided brake lines. Get you and one or two of your other friends and spend about an hour doing it, not that bad, i recomend an empty pepsi 2 liter bottle to drain into, so you can see the fluid coming out and its big enough to hold all the old and new fluid. I figure with the fluid that cheap I can change it every year or so and not be in for a big hit on the wallet. Get one of the bleeder kits unless you can get your hands on a clear tube for cheaper, clear tube really helps it.
What year is your classic? 93 or 94? What all have you done, plan to do, or stuff like that.
93 classic
