1 - 11 of 11 Posts
I just advanced my timing to 17 yesterday (i always run 91 octane)...anyways I took a couple "test 1/4 mile" runs yesterday ;) if ya know what I mean, and every time I reached redline in 1st or 2nd gear the RPMS would drop abruptly and the car would shoot forward...like slamming into an imaginary brick wall... I was thinking this could be the rev limiter on the stock ECU, or do you think it could be the car pinging? Thanks :)
BTW: My brake pedal sags when the car is running, but when the engine is off it's firm as a rock. Vacuum leak?
yep rev limiter.
what rpm do you shift at?
REDLINEse-r said:
yep rev limiter.
I normally shift at 7000, but I guess I should let off WOT earlier in order to avoid the rev limiter... Planning on getting a G20 ECU eventually. Think my times will improve if I can shift at 7,500 RPMS?
Thanks guys.
Will bleed the brakes... wonder why the pedal is hard with the engine shut off though.
nizzan4u2nv said:
The master cylinder doesnt work when the car is off.
...ah ic
sellout
The brake booster is operated by engine vacuum. When the car is not running the remaining vacuum is used when you pump the pedal a few times. All cars do this.
yea i know...i figured that if it was air in the brake lines i could feel it with the engine shut off. apparently i got it backwards. :D
Thanks guys.
It's fuel cut and you are experiencing a lazy tach most likely. The motor is outrunning the gauge.
Don't bother shifting a stock cammed B14 at 7500rpm with hopes you'll gain acceleration. Not going to happen. In fact when I went [email protected] on the totaly stock 97 aside from the airbox removed I actually short shifted.
Discussion Starter · #11 ·
i see, thanks for the info... i have a 91 B13 intake cam, but i know that is still stock...will get some JWT's eventually
1 - 11 of 11 Posts
