SR Veteran
What up fellas, i want to replace the stock carpet w/ a fresh clean one that doesn't smell like hot garbage. Is there anywhere I can order one already cut to size for the vehicle or would I have to go to Nissan. I have 96 200sx SER and want a stock carpeting. Any ideas on pricing? Thanks in advance.
"The strong move in silence, the weak start riots..."
Try calling a body shop. I'm sure they'll know where to get one.
96 w/ HS CAI, timing @ 17, 92 I/E cams, Naxos muffler, Eibach Sportlines, Front struts: Motivational, Rear shocks: KYB AGX's, S/T sway bars, ES lower control arm bushings and motor mounts, Courtesy F/R STB, APC Clear corners, Stillen grille, and Focus short throw.
Pew Pew Pew
Yeah you can buy one already fitted and that's the best bet. You might want to check with JC Whitney. If you were in Florida I could get you one for cost. I'll check and see if I can find somewhere that sells them nationwide.
