1992 Sentra SE-R
Purchased as a rolling chassis in 2003 from the original owner, this car went from Texas to Southern California to Vermont- only to spring an oil leak and die on the owner before he got to drive it more than a couple months in the fall of '02. This car is rust free, but has dents in a few spots. A few dent pulls and a fresh coat of black and this car will look brand new. Just to be clear, this car has ZERO chassis rust or rot of any kind.
Engine/Exhaust
Avenir long block (8.5:1)
Garrett GT28RS disco potato (~1000 miles on it)
Extrude-honed exhaust housing and thermal coated
Extrude-honed and Swain coated Avenir manifold (White Lightning)
550cc RC Engineering injectors (flow balanced)
Walbro 255lph fuel pump
JWT S3 cams
UR lightweight pulleys
JGY stainless 3" downpipe
3" stainless turbo-back exhaust from Dave & Liz's Magical Straws and Asspipes
Resonated test pipe (no cat)
Prothane motor mounts (powdercoated mounts)
JGY fuel rail
Drivetrain/Suspension/Brakes
2000 Sentra SE transmission (B15) with stock VLSD (~20k non-turbo miles on it)
Stillen lightweight flywheel
Clutchnet carbon/kevlar disc with JWT stage 1 pressure plate
Koni/Ground Control suspension (350/300 spring rate)
Powdercoated strut bodies
Koni bump stops
Altima MC
Fastbrakes 11" kit (Brembo 4-piston calipers)
Custom Steel rear BABK (not installed)
New Progress adjustable rear sway bar (not installed)
Stainless brake lines (front and rear)
Cooling/Plumbing
Nismo thermostat
Koyo SE-R radiator (coated with black heat emissive coating)
Johnnyracecar.com FMIC (25" W x 7.75" H x 2.75" D, coated with black heat emissive coating)
Hotshot IC piping
GReddy Type S blow off valve
Misc.
Freshly rebuilt and powdercoated control arms (new poly bushings and ball joints)
Powdercoated stock front sway bar
Nissport oil pressure adapter
Custom Steel water temp adapter
Custom Steel thermostat neck adapter (for turbo coolant feed)
Stainless water/oil lines
Autometer mechanical oil pressure gauge, boost gauge, and water temp gauge
Electrics
GReddy Profec-B Type S boost controller
GReddy turbo timer
Cobra MAF
JWT ECU
Cosmetics
NX center console
RedlineGoods leather shift/e-brake boots
Tsuru headlights/grill
6500k HIDs with halogen high beams
15" bronze Gram Lites with 205/45 Hankook RS-2 tires (brand new)
B14 SE-R wheels with 205/50 Dunlop all-season radials (75% tread)
