1 - 2 of 2 Posts
Alright turbo junkies, I've had this turbo laying around a while, and wanted to see what the experts think. I have a gt2554r BB on my Mazda right now, and it's starting to whistle....
Here are the specs for the Grand Prix turbo i have laying around:
Cooling: Water and Oil
Lubrication oil flow: 1.2 L/m SAE 30, 90Degrees C, 2.75 Bar
Bearing: Floating sleeve
Turbo Complete Part number: 465939-2X
CHRA Number: 431876-29
Compressor housing casting number: M24
Compressor A/R: .80
Compressor wheel trim: 70
Compressor wheel diameter Ind/Exd: 1.69”/2.02”
Compressor flow: 29 lbs/Min
Turbine housing casting number: M4
Turbine A/R: .68
Turbine wheel trim: 62
Here are the current BB GT2554r specs :
Ball bearing
* Oil & Water-cooled bearing system
* Smallest ball-bearing turbocharger
* Internally wastegated turbine housing
* T25 turbine inlet flange
* Great size for applications w/ packaging constraints
* Ideal for smaller displacement engines making up to 270 hp
Compressor Specs:
Inducer: 42.0mm
Exducer: 54.3mm
Trim: 60
A/R: 0.80
Turbine Specs:
Wheel Diameter: 53.0mm
Trim: 62
A/R: 0.64
Type: Internal Gate
How do you think the Grand Prix t25 will perform compared to my current GT2554r ? Thanks a lot guys.
Discussion Starter · #2 ·
Nobody knows eh ? I'm assuming the pontiac t25 will spool a bit later, and flow better at higher rpm, slightly. Anybody ?
1 - 2 of 2 Posts
