1 - 19 of 19 Posts
Pew Pew Pew
Ok I plan on boosting by the end of next year. I want to become well read on this subject. Can someone advise me on some books to pick up on this topic? I figure it can't hurt to have more info.
Not another civic....
Hmmmm I can suggest a magazine. Mike Kojima is a avid contributor to Sport Compact Car magazine and has taught me a lot with his write-ups. He has a series of write-ups that will be in this mag and you should keep an eye out for it. I am not quite sure what it will be...something like Turbo School or near there. Keep an eye out for it in the upcoming issues.
David is right! Maximun Boost by Corky Bell is a very easy to read/understand book for the boost impaired. There is also a very interesting write up on Water Injection.
Louis Anaya 1992 Sentra SE-R
13.6 @ 111 mph(Street Tires),12.7 @ 112 mph(Slicks), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Kuhmo 205/40/ZR17 Tires
I am pretty sure you can get it at any major bookstore; Borders, Walden Books, etc...
You may be able to find it @ www.amazon.com.
13.6 @ 111 mph(Street Tires),12.7 @ 112 mph(Slicks), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (7-9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Sumitomo 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24x8x13 Slicks(Drag)
El Chingon
Hey Louis, I know this is a bit off topic but, did you still need those front struts? I haven't checked my e-mail lately (haven't been home) and I don't know if you still wanted 'em or not. I'll be here at work until 2 today ([email protected]). After that, I just use the @home address.
1 - 19 of 19 Posts
