<font face="Verdana, Arial" size="2">Originally posted by Thomas Reynolds:
Um, wouldn't this require PURGING THE FREON?!?!? The radiator is not a problem, but messing with my A/C system is a HUGE one for me. I thought someone said on the list that if you removed the fans and the radiator you could (since you are angling the drill) fit a drill and bit right in there.</font>
Yeah it requires you to purge the system,
It's not that huge of a Job, If they said that Id like to see them do it, the drill wont hit the angle you need by doing that, so either remove the ac and radiator, or get a 90deg drill bit, that may break. It's not that hard your making it sound worse then it really is. Also their are 2 ways to get rid of the Shavings 1 drain the oil and remove the pan or, Drill it with the oil in it then tap it then fush the system and change the oil. Ive never done it the second way but I heard it works with no problems.
Mike.
Turbo Classic, T3/T04e Tial 35mm ".65Bar" Blitz BOV, Custom piping griffen intercooler Core with HK$ EndTanks,custom manifold, 370cc injectors, paxton fpr, Eibach Sportlines, everything else was stolen,
Pectel coming up bigger Injectors and custom fuel rail. DAMN VILLIANS.
