make sure every friggen bolt on that thing is tight! im paying for it right now, cus all the bolts are loose and i have to take it apart this weekend. good luck!
· Tired!
Just hand turn the motor a couple times to free up the crank and all that. THey crank the motor over with the ignition coil unpluged. THat will lube everything up and pump oil to the turbo. Then fire it up. Watch for oil and coolant leaks.
Brent
