1 - 2 of 2 Posts
Nissan Guru
Can you share your settings for the serial to usb adapter settings found under the properties of your adapter driver. I'm using XP.
Also what driver are you using? i think mine says profilific.
Nissan Guru
Discussion Starter · #2 ·
After searching till I was blue in the face I found out that all the settings for the serial to usb adapter in winxp are all good. (what ever the default settings are). If you anybody's wondering they are:
Baud: 9600
Start Bits: 1
Stop Bits: 1
Parity: none
Flow Control: none
think thats it. I had previously though my settings were wrong since my DIY consult interface/ cable was not working. I had found my problem to be the wiring right at the consult connector, my end not the car side. lol.. Works great now :biggthump
1 - 2 of 2 Posts
