1 - 11 of 11 Posts
I was hoping to powdercoat all the little brackets on the VE before I put the engine in. I have found out that the AC bracket from the VE does not work, and I have to use the one from the DE. What other brackets will I be swapping over? I dont want to pay to have parts powdercoated that I'm not going to use. This should also save me a little time having to figure this stuff out on my own. TIA.
-Mike
agent camel toe
a.c. lines..ps line..alternator bracket..ve intake manny...de throttle body
agent camel toe
b13 maf yes...max maf no..ill just keep mines that ugly blk for now..or rattle can it
Discussion Starter #9
Well I dont think I've ever seen a VE come with AC or PS lines, so those will be from the DE. I wouldnt coat those either. VE IM obviously goes with the engine. I'll be using the VE TB, not the DE.
So basically so far for brackets I need to swap over are:
-AC
-Alternator
-passenger side motor mount
Anything else? Do all the... I dunno what you call them, the brackets that the Axles go through on the VE work?
My MAF is in fact plastic, so yeah, don't think I'll coat that...
agent camel toe
My MAF is in fact plastic, so yeah, don't think I'll coat that...mpg9999
de's are metal
1 - 11 of 11 Posts
