1 - 20 of 23 Posts
· Jah Rastafari
choaderboy2 said:
Is the VE N-1 and GTI-R 54C crank pulley interchangeable?
Mike
I am 100% sure that the GTIR, N1 and 20V crank pulleys are the same or interchangable.
· Premium Member
Thank you for the advice! I was asking because Unorthaodx has a underdrive pulley for the GTI-R 54C front cover and I wanted to use it on the N-I cover I am putting on my new motor.
Mike
Mike
***Mike,
The 54C GTi-R crank pulley will only work with the N1 front cover if you machine the rear lip off the small pulley that drives the water and power steering pumps. The small rear pulley portion has a raised lip that helps to keep the belt centered on the pulley. You will need to put the pulley in a lathe and turn down this lip until it is the same height as the other "ribs" of the pulley. Go ahead and test fit the UR pulley on the N1 front cover and it will make sense when you see it.
Good luck,
· Premium Member
Mike
So does that mean we can use UR pullies on a VE now?
· VE junkie
no it means they have a crank pulley for a 20V motor or N1 motor. not a 189 hp motor like ours.
and you would only need to machine the pulley if you still have power steering and a belt driven water pump, right?
· No soup for you
v8killer2001 said:
***Mike,
Good luck,
Good stuff. An underdrive pulley, probably won't require this though. Just a thought.
John
I am using the Gti-R 54C crank pulley with my SR16VE N1 oil pump on my BB DET. The pulley had to be lathed down a bit to work, just like V8killer said.
Can I order the unorthodox crank pulley directly from them? Mike, have you tried it yet?
· Premium Member
Isn't the N1 front cover bigger than ours? I haven't compared the two, but why wouldn't this pulley fit?
· easy 400WHP
The GTiR pulley will only fit an N1/VE pump by grinding off the rear lip, which really isnt necessary if you know how to install belts. The VE pulley is different from the GTiR pulley. I too would like to try the UR GTiR pulley, but Id hate to have to hack it up.
· newbie
Mike
You can thank me for that!
· easy 400WHP
well first I wanna get it and see how it fits on the VE pump.. underdrive usually means smaller so it may clear on its own , unlike its larger stock counterpart... if indeed it does need to be cut down... thats the easy part.....the trouble im having is finding the actual UR 54C pulley,.....
1 - 20 of 23 Posts
