1 - 20 of 37 Posts
Red line chaser
Sounds good to me.....so good to me. ;)
Did your numbers change any since the last dyno? Any changes?
The sound of the intake cam hitting is tight, but when they both kick in, it sounds hella tight.
Same numbers really. 186whp / 140wtq. I had more RPm pills to try out. I ended up with 4500 intake, 5500 exhaust. That gives more of a smooth power band. I also messed with fuel pressure, but I think the AF gauge was off. I had the pressure turned up big time, and it still showed I was running lean. I will have a test pipe on Wednesday, but I'm not sure if I'll dyno anytime soon.
Wow those cams switch over and the car just gets angry. I like it :D
I wouldn't trust that tailpipe reading running a cat at all, your A/F was probably fine. You should have pulled your first O2 sensor and screwed the wideband in there.
You got SERVE'd
Sweet man, i cant wait till mine is installed! What kinda bolt ons you have?
Discussion Starter · #17 ·
I have a HS CAI, Fujitsubo header, Courtesy cat back, SR16 cams, Nismo FPR, and JWT ECU. Right now I'm at 186whp. I'm still using the stock cat, but I have a test pipe at home that I just got. The best cam crossover points I found are 4500 and 5500 with my setup.
AWD owns me
i wanna see a view of the tach when vvl kicks on. nice video. it's like when i look in the sr20ve section, i want a vvl. And the same goes for the turbo section.
1 - 20 of 37 Posts
