1 - 20 of 256 Posts
It has been suggested that we have a thread devoted to the 1/4 times and HP that a VE makes with varying levels of modifications. So post up your dyno sheets, 1/4 mile times and MPH. Please include all relevant info. This is not a discussion post but a place for people to get info in a concise place about ¼ mile times and HP. Happy Motoring :biggthump
Discussion Starter #2
2.372 60', 14.368 @ 98.09 MPH
2680lbs with me in the car, Crappy traction and spinning in 2nd gear a little.
That was with 185whp, Latter I got 189whp and 155ftlbs of torque. Mods are SR16VE cams, CAI, Fuji Header, 2.5 exhaust. JWT ECU with 8000rpm redline and Nismo FPR to lean it out just touch.
root
162WHP
132Ft Lbs
Best time is a 14.3 @ 95mph
VE injectors, DE MAF, DE ECU, 20V exhaust manifold, 2.6" exhaust, with electric dump valve, HKS WAI, MSD triggers (@4000/4200), SAFC-2, MSD 6A, power steering removed.
I don't my whp but my mods are SR20DE/VE 11.1cr, PR Cai, Gen6 header 3" exhaust, UR two pullies set Sr16ve cams JWT ecu set fo DE 11;1 cr and c3 cams with 370 injectors and bored maf (i think this ecu setup is killing my HP a litle bit) my best 1/4 mile is 13.80 @ 98.98 with 2.14 60' And my b13 is gluted but I weigth 300lb so that would add to a 2450lb car with me inside
BAD FKR
91 SE-R Hotshot intake/Fuji Header/Apex-i 3in Exhaust/JWT ECU/N1 cams/JWT valve springs & titanium retainers (more parts coming)
I know with cams not working power was at 154HP and 132 ft-lb of TQ car ran 14.7 but I do not remember the MPH. This was with SR20VE cams and 2.25in exhaust.
With cams working, N1 installed and still with the 2.25in exhaust the car. The car dyno'ed at 189HP and 136 ft-lbs TQ. I have yet to take it to the track, however I do know that it is somewhere around a 13.6 car (please do not ask how I know because I will not be able to talk about it here). Now I have a 3in exhaust and waiting to dyno again and go to the track.
SR20DET Slave
Hey guys...I have added/changed a few things in the N.A. 1/4 mile times list...I have added a V for JDM SR20VE's and a D for JDM SR20DE's along with a few other changes...If you guys have any other ideas let me know
Mine is a Primera Wagon with an unmodified SR20VE and a power sapping CVT M6 transmission weighing in at 3240 lbs with me and the fuel.
1/4 mile time is 16.95 seconds at a screaming 86 MPH.
Dynoed at 115 WHP (woopie)
Is that wrong??
kesi24 said:
223 Hp and 159ft lbs
Custom CAI,Header, greddy exhaust, N1 cams/springs,UR pulley ,emanage.
12.7 @105 w slicks Dailydriven.
WHOA, THAT IS QUICK. What kind of car was that in??
I see these low times and start to think what my car will do, but then i remember I have a heavy P10, instead of a B13. I think my P10 is around 2500lbs. I hope the aggressive gearing of the B15 helps me out.
Give a more elaborated description of your setup because obiously there are more parts and work involved on the engine and the car that the ones you are telling.....
WASHED UP
My car has CAI,greddy exhaust,custom headers,ur pulley,n1 cams,valve springs ,TB,tomei gears set @ 0 because they make NO power anyother setting.I have emanage on my JWT ecu.and msd to switch cam at 5k both at same time.I also have e-water pump.act clutch kit .I think thats everything. :biggthump
BAD FKR
Did you also get the 1/8 mile time. I am curious because the nearst track here is only an eighth. I kinda want to compare for shits and giggles. The nearst 1/4 track is about 2hrs away. I plan to go sometime during the summer.
agent camel toe
kesi's vvl is sick..sounds great and looks killah...best vvl ive ever heard
1 - 20 of 256 Posts
