I just finished putting the ve in my 91 g20. It runs but when driving it stubles and cuts timing at 2500 rpm. In fifth gear seams like it will go through the whole rpm range. All of my sensors appear to be in good working order according to conzult. My coolant temp doesnt go past 186. I though operating temp was 205? Im using the ve maf, b13 distributor, and realtime v2. Timing is set to the 3rd tick after the yellow tdc mark which i believe is 15 deg Btdc. No codes! Please help.
Nissan Guru
Sounds like limp mode to me. Check your maf sensor and wiring? im not familair with the realtime ecu? but that needs to be programed for the ve maf or stock de maf. Hope that helps
SR22VET GODNESS!!!
anyone know where i can get a sr20ve ecu pin out?i need help.i got og ecu & hsrness..
