I was tracking my car (NX with a stock VE) last weekend and noticed that after 5+ minutes of racing the oil temperature was between 250-260 deg F (measured in the oil pan just above the drain plug). I was wondering how high is high, please consider the following conditions:
- Mobil 1 10w-40 was used
- Air temperature was around 15 deg Celsius (59 deg F)
- Coolant was at 180 deg F at all times (Stanza pulley helped)
- Oil pressure stayed at 80-90psi most of the time during acceleration
- RPM band was between 3.5K - 7K (frequently shifting at 6.7K which was actually 400 rpm higher than what the consult showed after the runs)
As a reference, during highway drive the oil temperature is 170-180 deg F.
Is this a safe temperature or should I increase the viscosity of oil (10W-50).
Also what is the drain interval for oil changes at the track that you guys go by, I did around 120km at the track (15 min sessions followed by cool down which I took advantage to cool down the brakes plus cool down the oil to 220 deg F before parking the car for another 10 min between sessions) on the weekend and considering changing the oil every 1500 km running at the track. Let me know your opinions, thanks.
