· Premium Member
Ok I have reached a point where my install is almost done on my b15 SE but I want to put in some clean water and oil lines for my gtir t28.
The oil inlet line is all set but I am running into some uncertainty with the oil drain and coolant lines.
I had bought a oil drain replacement flange from Road Race Engineering but that is the wrong size. I would like to use a small length of stainless line to go from the oil drain to the block itself.
Has anyone used either of the following pieces on their t28 and they have fit correctly?
http://www.atpturbo.com/Merchant2/m...OD&Product_Code=ATP-FLA-010&Category_Code=FLA
http://shop.vendio.com/funinfeenix/item/630387190/index.html
If you did use these was there enough room to use some 45 degree angle AN fittings so your could run a short length of stainless line?
The last question I have is about the coolant lines. I'm going to be be running the water neck adapater made by Yahnozha.
Has anyone tried to use some specific fittings on the inlet and outlet from the turbo? It seems like you would run into some clearance issues with them. I know people have mentioned the banjo adapater from ATP. Did you guys just buy the adapater itself like this...
http://www.atpturbo.com/Merchant2/m...D&Product_Code=ATP-FTG-002&Category_Code=GTBB
And if so did the stock banjo bolt work with the adapter.
I would rather not have to buy 2 of these...
http://www.atpturbo.com/Merchant2/m...OD&Product_Code=ATP-FTG-003&Category_Code=FTG
If I can get away with just getting the banjo adapter.
· Tired!
On the oil drain flanges, those look like the right pieces to me.
On the coolant fittings and those banjo bolts, you may be able to find some cheaper banjo bolts from earl's or aeroquip in their brake parts sections. Also, you don't HAVE to use a banjo fitting just because they came like that from the factory. Most that I see around here are simple hose adapters right into the turbo.
Brent
Don't buy AN fittings for the drain. I made the mistake and basically wasted $50. The space is just too short to have two AN ends along with two 1/2"NPT to -AN adapters. I'll take a pic tonight and show you what I mean. I ended up just using a very short piece of -10AN stainless hose.
· Premium Member
Thats what I figured and was wondering if anyone got it to work. Did you end up using a clamp on the stainless line and two barbs basically?
the only other real question I have is if those ATP banjos worked with the stock banjo bolts from the t28
